sarnade999
Aug 7, 2014, 6:47 PM
Post #5 of 8
(2238 views)
Re: [flyatyou66] PDP505XDE Green Dots in the Center of the Screen
Thanks again for all your advice. However, I cannot locate V-SCAN on the Y-Drive pcb. I have gone through the PCB with a magnifier glass and have listed below the Presets and Various Test Points. TEST POINTS: YSUS-MSK, YSUS-B, YSUS-D1, YSUS-D2, YSUS-G, YSUS-U2, YSUS-PD VH-UV-PD, YPR-U, SI, OC1, OC2, CLR, CLK2, LE, SUSOUT, YRSV-2 YDD-PD, Y DRIVE-PD, YDD-PD, PN-MUTE, DRIVE-PD, -VOFS, VOFS-ADJ, PRESETS: VR2201, VR2202, VR2203, VR2204, VR2402 VR2401 Labelled "VH-CONT" ( The only one with a Label) Because of only having 6 Presets, most of the Test Points cannot be adjusted from the Y-Drive PCB. And not having Labels for the Presets, making it impossible to know what you are adjusting unless you have a schematic, which I do not have. Pioneer are not making it easy !!. Thanks again
