enygren
Dec 28, 2004, 2:48 PM
Post #3 of 3
(1661 views)
Re: [Guest] Panasonic HDTV Connections
I have to agree with the input someone gave about Component cables vs. anything else. DVI (there are two types, so choose the "correct" one if you go this route) is true "digital to digital", so the pic "should" be great. However, on one TV, my component cables are easily as good. DVI also still requires you to add audio by separate cables. HDMI is also "digital-digital", and has the benefit of carrying the audio too, but most plasma's I've seen limit the screen sizes using either of these two inputs. For example, if you are receiving true, full screen HD signal, no problem. However, if you are receiving something other than full screen width signal (which happens a lot on local programming, some sports channels, etc.), the digital inputs won't let you use your TV's ability to fill the screen with picture. The black bars are annoying. There is also the issue of your TV having inputs that match your receiver, something I'm not fortunate to have currently. Component cables seem to bridge the gap between all the old gear and the new gear (even the inexpensive progressive scan DVD player on the market), and although they have to convert digital-analog-digital, their pic quality is pretty impressive. They are "cumbersome" of course, with 3 thick video cables snaking between components (and you have to have the audio too, but can use fiber optic if you wish). None are cheap of course. Wish I could help you with the receiver selection. Good luck.
