Guest
Unregistered User
Nov 3, 2004, 1:16 AM
Post #4 of 6
(3308 views)
MODEL ends with the letter 42PXU/P OR 25U/P's are currently new Panasonic displays intended for consumer use which has tuner built in. They are EDTV model which downgrade HDTV signals although It's not visible to naked eye when compared to HDTV Models . When your applications is viewing intended, they're at best as of your choice at the moment. It is rare that you find a good reviews at the moment cause it's yet not very long when they arrived in the consumer world. In a Industrial Worlds are: TH-42PWDUY is also an EDTV which tuner does not contain. It does display similar to the consumer models above cause they share 853 x 480 resolutions. I will not recommend for computer graphics though! However, the TH-42PHD6UY should your best option mainly bec. it's an HDTV capable which is computer graphics intended. You should not be completely thrown by an INDUSTRIAL model cause they're the best at the moment. Panasonic is highly recommended!. Actually, the TH-42PX25U/P is not EDTV, it's a Plasma HDTV (which means it's got a resolution of 1024x768, which is not real HDTV, which is 1,280x720, but is better than EDTV's 852x480)... As for the TH-42PHD6UY, it is indeed the stripped-down "industrial" model of the TH-42PX25U/P, which means it has the plasma HD resolution of 1024x768... For reviews, CNET has one at http://reviews.cnet.com/...96904-2.html?tag=top For the Panasonic EDTV panels, you want the TH-42PD25U/P, and it's industrial counterpart the TH-42PWD6UY...It's the highest rated plasma at CNET http://reviews.cnet.com/...16296-3.html?tag=top -Cheers-
