denonjapan
Sep 8, 2008, 3:26 AM
Post #9 of 21
(29909 views)
Re: [waltliu] Panasonic Plasma - Horizontal thin black Line
Well, goodluck! I just want to give you a straight answer without you hoping for anything. And with regards of exception for warranty coverage?. There should be direct from manufacturer for 2 years from the date of the unit being purchased. Services includes:. Free of labor, estimate parts and labor from the authorized PANASONIC repair service in your area. But here's the catch! > there are restrictions within their policy in replacing refurbish parts or glass panels in case their decision push through. Panasonic tech isn't going to tell you if you're not aware all of these. As far as the tech actually repair your unit inside your home isn't going to happen, if someone will come inspect your tv is only to observe all possible sign of abuse, improper usage or connections, and etc. In any event, Panasonic will then decide if to replace your unit to a refurbished model is most likely, and in order to get that coverage is make sure you purchased the tv originally from their authorized dealers or else, you loose.... Moreover, to date 2 years ago. Most plasma displays can reach 50-60,000 hours. That is the expected lifespan calculated based on a daily average users. That doesn't mean, all panels made should reach that expentancy. Some may reach even longer than expected, and some unfortunately will fail due to uncertainty. Their lifespan isn't just based on their name brand. it can happen to SONY or SHARP. it's not a matter of choice, it's their nature. take care! denonjapan made in japan
