Gandrewc
Oct 6, 2011, 1:52 PM
Post #2 of 4
(2173 views)
Re: [klydesign] Philips 50in" no picture
It seems that the power is still getting through to the led but not necessarily to the screen. If you look on the top of the TV, there should be some vents, see if you can see any light coming from inside there. If not then it maybe an electrical problem and you will need an electrical engineer to find and fix the problem. In the mean time why not check out some more 50 inch TV's or if you're a big fan of Phillip's TV's check out these instead, although this does seem to be quite a common issue with some of Phillips' larger TV's.
