jstiene
May 2, 2012, 7:02 PM
(1734 views)
Samsung TV with Vertical Line and Ribbon cable question
Hello...I have a 42" samsung with a black vertical line, about 3 inches wide or so. I decided to try replacing the buffer boards to determine if the screen or the board was bad. In replacing the board, I noticed that the particular ribbon cable right where the black vertical area is looked as though part of the silver contact that goes in the board connector was only half the side of all the other ribbon cables. I looked at the original buffer board and seemed to notice a small black spot. The ribbon cable has a straight edge on the end of it, so it doesnt seem damaged or melted, but yet is about 1/3 the size compared to all the other ribbon cables that are aligned across the bottom. Has anyone encoutnered this before? And is there anyway to replace this ribbon cable on the panel? I dont think it can, but thought I would check with those that have more knowledge than me. Any advice is appreciated...trying to determine if the panel is useless...there are no cracks btw... Thanks
