kdh2010
Feb 23, 2012, 7:39 PM
Post #8 of 8
(4992 views)
Re: [popemike] Sony KE-42TS2U Chip replacement 1019
<quote>I put in a reccycled B-Board and same problem as before. The power led lights up, the fan comes on, the screen flashes very quickly a white light, the sleep timer light flashes once, relay RY101 clicks on the power switching board, then the power goes off - shuts everything off - remains off for 30 seconds and same happens again. This will continue 2-4 times then it shuts off. <br> <br>Is this still a B Board problem - did they send me a bad BBoard?<quote> Hi, This is really a late reply. But, it might help someone sometime. I just ran across one of these tv's doing the exact same thing. I believe it does not stay on because it is getting a feedback signal that it is not happy with. Mine turned out to be the x-sus board (usually referred to as the z-sus). It was a cap in the upper right hand corner - C49. It is a 10uf tin cap. It is right by the lm358 op-amp. There are two there; it is the lower of the two. If it is your problem, you should be able to heat it up and the tv will stay on! Give it a try. And good luck!
(This post was edited by kdh2010 on Feb 23, 2012, 7:46 PM)
