NoelCarboni
Jul 28, 2005, 1:05 PM
Post #15 of 41
(7505 views)
Sigh, it appears I must join the growing list of you with 42B1s who have the "fails to start / blinking LED" problem. This, I assume, is the result of some failure of the system as detected by the Power On Self Test logic. Mine is intermittent, and may be related to temperature (i.e., it seems less likely to come on if the system's warm). Sometimes it works, and sometimes it won't come up, apparently rebooting and trying again several times, as evidenced by the LED going briefly to green, fans starting, and short light burst from the display. Once or twice it even shut off after running fine for quite a long time. It seems to be getting worse. At least once it showed a pattern of 6 red LED blinks, and from what I gather above this implies "PANEL FAIL (PDP)", whatever that means. Seems unlikely it's a hard failure of the display, because when it works it looks great. I haven't purchased a service manual yet. I'm decent at fixing high tech stuff. My question is this: Is the service manual going to be enough to facilitate this, or does one need Sony training (in other words, should I even try or should I just give up and throw money at the repair center)? Thanks for any wisdom you can offer. -Noel
