WIERD Problem with my Phillips Plasma Tv
networkable
Aug 29, 2006, 11:43 PM
Post #1 of 6 (660 views)
WIERD Problem with my Phillips Plasma Tv Can't Post
FrownFor a little bit my Plasma Tv has been ghost trialing/distorting the image a little bit. But when i tap the right side the or the back right or middle of the tv the tv gets a little brighter and the ghost trail/imprinting wierd diplay goes away for a while. The tv is stil watchable but its starting to annoy me. It would do this once and a while now its doing it more often. Any idea's?
model 50fd9955-
Thanks Brett
(This post was edited by networkable on Aug 29, 2006, 11:43 PM)
networkable
Aug 30, 2006, 8:38 PM
Post #2 of 6 (643 views)
Re: [networkable] WIERD Problem with my Phillips Plasma Tv [In reply to] Can't Post
Now its doing this ;( it woulc work for a minute then go to this then work again etc etc i am thinking maybe a fault on the digital processor pcb or somehting. any one have idea's?
(This post was edited by networkable on Aug 30, 2006, 8:39 PM)
Attachments: Plasma Screen Problem.jpg (38.3 KB)
Aug 31, 2006, 2:53 AM
Post #3 of 6 (639 views)
Its either a fault in the digital processor or the pdp panel. check the edge connectors first for bad joints by prodding around with a plastic insulated stick to see if the fault comes and goes. if its the front panel then dump the tv or take out a second mortgage to buy a new one
networkable
Aug 31, 2006, 3:46 AM
Post #4 of 6 (637 views)
Re: [techchris] WIERD Problem with my Phillips Plasma Tv [In reply to] Can't Post
Which one is the digital processor the back one that connets to the whole a/v inputs ? its donest seem to a problem with the pdp i think its just the board.
(This post was edited by networkable on Aug 31, 2006, 4:03 AM)
Aug 31, 2006, 12:01 PM
Post #5 of 6 (630 views)
the processor/scaler board is usually connected to the pdp with a couple of short flying leads but I dont have a circuit for that tv so I am only guessing.Usually fixed in the middle as you look from the back. might be worth checking the driver pcb's around the edge of the pdp for bad connections too.
MOtvGuy
Oct 14, 2006, 8:09 PM
Post #6 of 6 (543 views)
The digital board is mounted under the SSB board as I recall.
