Why are there still black bars when I play a widescreen DVD?
Guest
Unregistered User
Dec 22, 2003, 9:19 PM
Post #1 of 5 (3455 views)
Why are there still black bars when I play a widescreen DVD? Can't Post
I have a panasonic 42" and when I play widescreen dvd's it still has the bttom and top blacked out, even when I have it on zoom. I started buying full screen. The TV is of couse 16:9. Why won't the screen. I have tried all of the ascpect settings and nothing seems to work.
JRC
Mar 20, 2004, 1:33 PM
Post #2 of 5 (3300 views)
Re: [Guest] Why are there still black bars when I play a widescreen DVD? [In reply to] Can't Post
Here is a quote from Ken G, who posted this wonderful information. Before you read this however, it sounds to me as if your overscan is set incorrectly. Purchase AVIA or DVE and check to make sure your picture size is set up correctly.
Quote from Ken G. in regards to viewing black bars on a 16:9 television...
"Ok, you bought a widescreen TV, right? That's great. The OLD TVs have an aspect ratio of 1.33:1 (4x3). Your brand new widescreen TV has an aspect ratio of 1.78:1 (16x9). Ok. HD broadcasts are shown in a 1.78:1 aspect ratio and they will fill your screen on your widescreen TV. If it's displayed on your old 4x3 set, it'll have black bars on the top and bottom. Why? Because the 1.78:1 aspect ratio of the program is WIDER than your 1.33:1 TV. So therefore, the image is shrunk to fit the width of your TV, thus leaving black bars. Ok, you're getting it now.
So, what about movies? Well, most movies are either filmed in a 1.85:1 aspect ratio, or a 2.35:1 aspect ratio. Yeah, the DVD may say 16x9 on it, but what that means is that it's "ENHANCED" for 16x9 TVs. It doesn't mean it's gonna fill your screen. 1.85:1 movies may fill your screen, depending on the amount of overscan. 2.35:1 movies won't fill your screen. Why? Because it's WIDER!! Therefore it has to be shrunk down to fit the width of the screen perfectly. Black bars at the top and bottom are normal to preserve the original aspect ratio of the movie. Widescreen aspect ratios range from 1.66:1 all the way up to 2.76:1 (Ben Hur). The wider the movie, the bigger the black bars. Widescreen TVs are mainly meant for HDTV viewing. But they sure make watching movies a lot better too because the black bars are either gone for the 1.85:1 movies, or a lot smaller for the 2.35:1 movies.
Yeah, I hear this a lot in those threads. "Why can't they just film at one aspect ratio and stick to it?" Directors and filmmakers film mainly for the theater and don't give a rip about the TV's aspect ratio. Plus, 2.35:1 movies mainly use an anamorphic lense to compress more of the picture onto a 1.37:1 frame. This method also increases the quality and makes it look better than hard matting, soft matting, and Super 35. 1.85:1 movies are either hard matted, soft matted, or filmed in Super 35. 2.35:1 movies are either shot in anamorphic, or filmed in Super 35. Now, if the movie is Super 35 and has an aspect ratio of 2.35:1, some directors choose to open up the mattes a little bit to fill more of the screen like they did in Austin Powers International Man of Mystery and The Recruit. I really have no problem with this time of reformatting as long as it's up to the director and it still looks good. Some Super 35 movies are opened up a little bit if the director decides that the 2.35:1 composition is way too tight. Other reasons why most Super 35 movies AREN'T opened up a little is because a lot of the movie was hard matted for the special effects. If some of the movie was opened matted a bit, then some other parts of the movie would have to be "pan and scanned". And that's not good.
Directors choose different aspect ratios for different reasons. A lot of action movies are done in 2.35:1. A lot of the comedies are filmed in 1.85:1. Each aspect ratio is appropriate for different genres.
So, if you pop a movie in on your widescreen TV and still get black bars. Look on the back on the DVD and see if it says 2.35:1. If it does, then you're ok. If you pop in a 1.85:1 movie and don't get black bars, you're still ok."
Denet
Unregistered User
huiwu924-banshee@yahoo.com
Sep 15, 2004, 9:36 PM
Post #3 of 5 (2751 views)
Re: [JRC] Why are there still black bars when I play a widescreen DVD? [In reply to] Can't Post
Hi JRC,
I just read your post and you are very knowledgeable about widescreen and HDTV. I have a question about channels are broadcasting 16:9.
I just bought a Panasonic PT-47WX53 HDTV ready widescreen rear projection TV.
When I tune to channels broadcasting 16:9 widescreen, my TV picture has black bars on the top and bottom and the picture is squashed. I played with TV aspect mode: Full, just, Zoom and 4:3. Nothing helped.
Why is that?
My DVD player has black bars on the top and bottome but the picture is fine.
Thank you for your help.
My setup:
Regular RCA dish receiver
Memorex progressive DVD player
Smile
JRC
Sep 15, 2004, 11:18 PM
Post #4 of 5 (2736 views)
Re: [Denet] Why are there still black bars when I play a widescreen DVD? [In reply to] Can't Post
Hey there!
I'm not sure why your picture would be squashed, but I do know that most set top boxes (your cable box) forces a set mode when they output HD material.
Basically, if you turn to watch CBS on it's HD channel, and the show being broadcast was NOT recorded in HD, you'll see a 4:3 show with sidebars. You won't be able to change the aspect ratio using your TV remote, as the STB has locked your ratio.
The moment an HD show does come on, it will automatically scale it to the proper size, 16:9.
You said that you get bars on the top and bottom of your TV, and the contents are squashed. Do you get bars on teh sides as well?
Also, do you get black bars on the top of 1:78:1 or 1:85:1 movies? If so, your DVD player needs to be set to widescreen. Also, check to make sure your RCA receiver is outputting 16:9 or "widescreen".
I hope that helps! :)
Guest
Unregistered User
Oct 7, 2004, 1:51 PM
Post #5 of 5 (2580 views)
Could the black bars from the 2.35:1 Wide Screen burn your plasma will watching a 2 hour movie?
