Nov 3, 2013, 9:05 PM
Post #6 of 6
(2230 views)
Re: [coax] ASUS TLW42001D no power
coax;.... 1st off , I need to tell you that I do not work on these types of TVs..... There are several VERY good techs here that may come along & help you much better than I can... Hopefully soon... I , too , could not locate a Service Manual for this TV... Lots of User Manuals & Driver updates , but NO Service Manuals... But , from what little I do know , it sounds like a power supply problem... From what I learned here , look by the connectors on the power supply panel for printing or labels with the voltages printed on them... Use the ground pins ("-") on those connectors for your readings.. Also look at the lytic caps on the PS panel for bulging at the tops or swelling at the tops &/or sides of the caps... Good Luck...... Later...Ron.M...... Veteran & Retired TV technician
