panasonic TXP46G15 No power
Jules
Sep 14, 2014, 9:16 PM
Post #1 of 14 (3505 views)
panasonic TXP46G15 No power Can't Post
Hi Guys,
I have a panasonic TXP46G15 with no power.
Seems to be no shorts from all boards so points to power supply. Can anyone help on this please?
Thanks.
Regards,
Jules.
Sep 14, 2014, 10:15 PM
Post #2 of 14 (3499 views)
Re: [Jules] panasonic TXP46G15 No power [In reply to] Can't Post
"When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit."
Jules
Sep 15, 2014, 3:17 PM
Post #3 of 14 (3485 views)
Re: [jts1957] panasonic TXP46G15 No power [In reply to] Can't Post
Thanks JTS, I get 6 flashing lights on it.
Sep 15, 2014, 6:25 PM
Post #4 of 14 (3480 views)
Pin 65 of the CPU IC9003 monitors the status of the SC board. During normal operation, a low is applied to pin 65. If the SC board becomes defective, a high is provided to pin 65. As a result, the unit shuts down and the power LED blinks 6 times.
Jules
Sep 15, 2014, 6:42 PM
Post #5 of 14 (3478 views)
Thanks JTS, So are you saying it is the SC board that is at fault? (transistors maybe)
Sep 15, 2014, 7:32 PM
Post #6 of 14 (3475 views)
That's what the literature (and my interpretation of it) seem to be saying (FETs most likely).
Jules
Sep 15, 2014, 8:31 PM
Post #7 of 14 (3473 views)
Thanks again jts, I will test them to see if there are shorts and try to order some. Having said that , I continuety tested the power connection on the SC board and there was no short at that point. <br> <br>Regards, <br>Jules. <br>
(This post was edited by Jules on Sep 15, 2014, 8:31 PM)
Sep 15, 2014, 8:51 PM
Post #8 of 14 (3470 views)
NO resistance reading at all between connector SC2 pins? How about any DC voltage?
Careful you do NOT try to run more than 30 seconds with ANY connector unplugged.
(This post was edited by jts1957 on Sep 15, 2014, 8:53 PM)
Jules
Sep 15, 2014, 9:11 PM
Post #9 of 14 (3467 views)
what should voltage be from PSU to SC board please?
Sep 15, 2014, 9:41 PM
Post #10 of 14 (3465 views)
Adjust driver section voltages referring the panel data on the panel data label.
Check or adjust the following voltages with the multimeter.
*See the Panel label.
Name Test Point Voltage Volume Remarks
Vsus TPVSUS (SS) Vsus ± 2V VR251(P) *
Ve TPVE (SS) Ve ± 2.5V Fixed *
Vset TPVSET (SC) 290V ± 9V Fixed
Vad TPVAD (SC) - 195V ± 2V VR16600 (SC)
Vscn TPVSCN (SC) Vad_base : 148V ± 1V
GND_base : - 47V ± 3V
VR16841
(SC)
Vda TP9 (P) 60V + 1V, - 2V Fixed
Caution:
Absolutely do not reduce Vsus below Ve not to damage the P.C.B.
(This post was edited by jts1957 on Sep 15, 2014, 9:43 PM)
Jules
Sep 15, 2014, 9:58 PM
Post #11 of 14 (3462 views)
This may be a little beyond me, How can I ajdust voltages?
Sep 15, 2014, 11:43 PM
Post #12 of 14 (3459 views)
What voltage is being measured currently at Vsus (Vs)? (You CANNOT adjust what isn't there.)
Panel Data Label should look something like this:
Final adjustment will be made with the TV working, with a specific signal applied and with certain controls set on certain settings.
Name: Vsus (aka Vs) (Voltage Sustain)
Test Point: TPVSUS (SS) (Test Point where to measure VSustain. Reference to panel/ground)(SS is the board where it is located)
Voltage: Vsus plus or minus 2 volts (from what is written on label)(Voltage expected and tolerance allowed)
Volume: VR251 (P) (Adjustment for Vsus)(Variable Resistor used to make adjustment. P is the board where the VR is located.)
(This post was edited by jts1957 on Sep 15, 2014, 11:47 PM)
Jules
Sep 16, 2014, 9:13 PM
Post #13 of 14 (3442 views)
Thanks jts, I will try
Sep 16, 2014, 10:21 PM
Post #14 of 14 (3440 views)
I really don't see how you can miss it this time.
