j,aguasin
Mar 31, 2014, 12:39 PM
(1550 views)
Re: [sai2006] polaroid TLU-03223B totally dead
what check up did you do??? only visual! need to read the primary voltage if have then read the secondary voltage if done and have a voltage need to trace all the voltage if the voltage is accurate may be the problem is motherboard. take note check the memory of regulator ic!...
