dcefiacsjr
Jul 15, 2010, 1:04 AM
Post #1 of 6
(9543 views)
vertical lines panasonic viera TC-P50G10
Looking for a little advice. I bought a Panasonic Viera TC-P50G10 February 14th, 2010. In May I had a black vertical line show up momentarily about 2 inches wide and just to the left of the center of the screeen. A week later, the line started showing up daily and stayed for longer periods of time. Best Buy came and replaced the "main Board" as per Panasonics diagnosis over the phone. Everything was fine for 1 week. Now the line shows up daily and may last ten seconds or may last an hour or two. Turning power off or on does not help, line shows up on all inputs, sometimes black, sometimes white with colored lines, sometimes yellow, red and black, sometimes flickering picture in and out. Best buy is coming to replace the same board again, but what would cause that board to go bad, tech is doing nothing to diag the problem. By the time this repair is done the second time, the price of the TV will be exceeded and it is only 5 months old. I feel there is something causing that board to go bad and replacing the board is just putting a "band-aid" on the symptom, not fixing the problem. Any insight into what may be going on would be greatly appreciated, thanks. I have photos of the line in different colors but do not know how to insert them into the post, or if it can be done here.
