plasmahell21
Jan 31, 2010, 3:53 AM
Post #1 of 6
(11892 views)
vizio plasma wont turn on
Have a vizio plasma tv (p50hdtv10a) that will not turn on. No sound, no picture, no red light, nothing. Checked voltage at psu. Have all the correct voltages 3,5,9,12,24 vdc at the output pin connectors expect at Va and Vs. On the back it says Va=60vdc and Vs=190vdc. I believe the psu is bad. I checked most of the caps and they are fine. I was wondering if the Va and Vs outputs only turn on when the tv is actually turned on. Should I see voltage at Va and Vs when the tv is powered up but not on? Has anyone else had this problem or have any ideas of what else to check. Thanks for the help.
