Nov 25, 2009, 7:10 PM
Post #4 of 5
(1801 views)
Re: [frankj] '96 Mitsu VS 5042 prob
frankj;.... but it seemed that the pic collapsed more from top-to-bottom before side-to-center. That simplifys things ,a little....Means you have a vertical deflection problem.... Most likely a bad IC now... Prior to your smacking the TV it was working & the IC was saveable... This apparently started with a / some bad connection(s) at the vertical output IC... With repeated smacking , you most liklely fried the IC & some other parts as well... I am the family auto mechanic.. 1st off , THANKS for your honesty....NO offense , but.... No electronics background, This part is a problem....^^^^ You have to recognize the parts involved , disconnect wiring cables , pull the chassis / board out to check parts , de-solder & solder new parts in , etc , etc.... This is not something I'd reccommend the uninformed & inexperienced to try & repair themselves.. With all due respect, I think you'd be better off calling a reputable TV repair shop.... Tell them you lost vertical sweep (& it's the IC) & ask for an estimate on repairs.... In my area , this would cost about $175 ~ $250 to fix... I would consider pix quality before it went out as to whether or not you go ahead with repairs.... Your call... I really wish I could've been of more help... But me (or anyone else) trying to help you is like you trying to help me with a strange noise coming from my car's engine.... GOOD LUCK..... Please let us know how you went with this.... Once again...HAPPY THANKSGIVING to you & your family....... Later...Ron.M........... Veteran & Retired TV technician
(This post was edited by Ron.M on Nov 25, 2009, 7:12 PM)
