Xeniczone
Jul 24, 2010, 12:46 AM
Post #14 of 22
(4565 views)
Re: [Ron.M] Blue ghosting. How do I fix?
You are adjusting G2 voltage to the CRT....I NEVER said it would affect contrast....I said it "may" affect "black & white" pix..... Ahh... I though you were suggesting contrast by that. My bad.
If it's only out a little bit , that could be from normal aging & the previous owner did not adjust the convergence.... You can set those adjustments by going into the "customer" menu , look for convergence & do it yourself..... No big deal.... Yeah I adjust that, I even looked up service codes for it hoping to get more adjustment abilities, but all it gives you is a better "convergence map" so to speak. Like the costumer menu gives you a cross in the middle of the screen while the service menu gives you a checker pattern. That shows of the thing I was talking about better. The center of the screen is perfect, but the farther out from center you get the worst it gets. But I guess your right, it isn't bad enough to invest money into.
Yes they are....But in your case NOT worth it.... Reasons are;.... Your TV IS old.... All 3 CRTs have the same hours of play on them & are at the same point of life left.... Replacing one CRT gives that color CRT dominence... ie; , If you replace the Red CRT , your pix may have a reddish background cast to it.... Therefore , replacing ALL 3 CRTs IS reccommended.... That IS costly & NOT reccommended.... Depends how costly it is. I would prefer to invest money into a newer Projection TV. Like when this one dies I will buy a newer one of craigslist or ebay. As you probably know they are cheap because they are bulky and rather outdated. Though, my dilemma is, I need a 4:3 CRT, and a prefer it to be large. So to me it may be worth the investment to have one of these restored, but personally I do not like this TV. Is there a specific TV that you would recommend? I like to keep it in the 55" range. I think 65" range is too big. I've never been a fan of Mitsubishi, but I do like Sony, Hitachi, or Samsung.
gives me EXACTLY the same problem.....(Using IE-8) BTW;...Notice the link above is blue....Means it's live.....Just click on it..... To activate the link , preview post & if needed click on the link to test it.... That way we don't have to open a new window & copy & paste your link , etc.... Yeah, not sure what is up with IE-8. I may have to do some research, but I'm more interested in the TV right now. I've never really like IE. I've always used Firefox or Safari (Which is an Opera shell), but they stopped making IE for mac so it's not a prob. for me. Again, Thanks for sharing your expertise. I will try adjusting the TV before I go to bed around 10-11, because I won't be here this weekend. And sorry if I implied I was mad before, I wasn't, I was just trying to correct your position on my electronic ability. I didn't mean insult as in an actual emotion.
(This post was edited by Xeniczone on Jul 24, 2010, 12:53 AM)
