CTC 195 - 61 inch rear projection vertical collapse.
Guest
Unregistered User
seshadri_srinath@hotmail.com
Jun 20, 2003, 7:44 AM
Post #1 of 2 (737 views)
CTC 195 - 61 inch rear projection vertical collapse. Can't Post
The TV had a picture collapse in half. I opened the back and adjusted it to make it full again and 2 days later it collapsed to nothing. It has sound but no pic. I did some testing and found bad capacitors which had leaked, finally I checked the test points and finally narrowed it to the eprom (Q14401 I think) But I'd like to know if anything else could be bad. And is a full main board available for it. If I buy the eprom do I need to program it and how do I do that??? BTW I am not a tech. I am just a TV watcher.
Thanks.
Srinath.
Guest
Unregistered User
edwardburn@msn.com
Dec 16, 2003, 8:04 PM
Post #2 of 2 (588 views)
Re: [Guest] CTC 195 - 61 inch rear projection vertical collapse. [In reply to] Can't Post
I am not sure what you adjusted but the board is repair at component level. I or another competent tech should be able to fix u up for 175-250$
