bugg
Mar 14, 2008, 8:03 PM
Post #3 of 3
(86 views)
Re: [LegalizeFreedom] Can I use TV projector as wall projector?
Yes, this is completely possible. I've done it. Mine projected from about 15 ft, onto painted wall. My viewing screen was approx 120-inch diag... Movies and XBOX games were absolutely amazing. A few things you'll need to tackle: Angle (all 3 crts should face straight) Focus (i had to remove the wingnuts from the lenses to allow greater focus adjustments) You'll need to make MAJOR adjustments to your focus, thats why you saw a blur of color... Just turn the focus pots and twist the lenses till you're happy. Distance (further away, less brightness, but bigger picture) Convergence (this will also need MAJOR adjustments) Safety (gotta build a cabinet so no one gets shocked) Does your RCA by any chance have the removable chassis? (The box) If so you've got it made. I wished for one of those when I built mine, instead I had to build a plywood box. My biggest problem was where to place the 'projector'... It has to be raised up to about mid-way up your desired 'screen', which poses a problem... Do you put it BEHIND the seating (peoples heads get in the way) or in FRONT of the seating (projector obscures view of screen)..... The image will never be as bright/sharp as it was when it was still a 'television', but it's amazing for video games/movies.... Just get ya a surround sound, you'll be at the theatre!
