TV guy 1966
Mar 7, 2007, 12:45 AM
(275 views)
Re: [joey28] Help with No Power????????????
Yes you have a power supply issue with your Toshiba DLP unit. This is not a common problem in this units history. Do you have power outages or power surges or lightning prior of it failing? If you don't have the nack to take things apart and though common sense and reassemble the item then you need to call a service man. If you can I can provide the service manual to help.
