easyab
Feb 28, 2010, 4:52 AM
Post #4 of 4
(2248 views)
Re: [Jimbo13] Hitachi 50V720. trick lamp
Re-install everything. Turn on power and listen at rear of the TV in a quiet room. If you hear a faint squeal, that is the ballast building up a High Voltage, High Frequency signal to apply across the bulb. If the squeal quits and restarts, then TV shuts down after 3 tries, lamp is most likely faulty. If lamp is normal, TV will start. The only way to test for sure is to install a new bulb or lamp. easyab http://calgary.convergencerepair.com/index.asp
