Nov 28, 2011, 10:20 PM
Post #2 of 4
(1894 views)
Re: [Hazardsneon] JVC AV-48WP74 Clock issues
Hazardsneon;..... I'm not that familiar with this model TV , but , I'll try my best to help.... I downloaded your manual... From what I understand , the "Sleep Timer" will NOT work till the clock is set... On page 19 it tells you how to set the clock.... I presume you did all of that... However one crucial step you may be overlooking is the "Start Clock" .... When you get to "Start Clock" press "OK" on the remote & that should start the clock... Let us know if that works... Good Luck....... Later...Ron.M....... Veteran & Retired TV technician
