erickeri
Apr 27, 2008, 6:53 AM
Post #3 of 14
(12294 views)
Re: [zip] JVC AV-48WP74 convergence problem!
Where can I get the rebuild kit for the tv? Thank you for telling me about the having the back removed, I didn't know that. It is a HD model Hi: It sounds like an convergence problem, this tv should have two large ic's on a large heat sink, these are the convergence ic's, their bad, change both. JVC has a rebuild kit to repair this circuit (Ic's and resistors). P.S. If this is an HD tv model, don't run this tv with the back removed! See service manual for info to defeat the saftey divice, you will blow out your hd circuits if you operate the set with the back cover removed!
