tenordiamore
Feb 6, 2005, 2:25 AM
(1630 views)
KP-53V15 Convergence Panel Settings Help
Hello, I read through some postings before I decided to send this request. A neighbor gave me a Sony KP-53V15 and said that all the adjustments had been "messed" with on the circuit board on the bottom front of the television. It sounds like this circuit board with a lot of micro-dials on it is called the convergence board, from what I have read. Anyway, I had a technician come and look at it and he shook his head because indeed these adjustments are all off. Someone thought that a chip might have been bad, but he said this is not the case. So, I am looking to get the factory settings for this circuit board and all it's micro-dials. Oh, as an FYI, it has a good enough picture for how old it is (mfg in 1993), convergence is off, or at least it seems to have different convergence at different points on the screen. The "frame" is better after the technician adjusted some of the settings. Sound is really good. It gets decent picture from an antenna. So, everything seems to work, other than colors are off, convergence will not adjust with the remote, as when you adjust it, it is different in the center than on the bottom or top. So, in summary, I am looking for the factory settings for the circuit board micro-dials (if that is what they are called) that is located below the screen on the front bottom of the TV (in-between the speakers). Thank you!! I did not feel like paying the technician an additional $250 dollars to do this. Brian Brian
