Mitsubishi VS-50805 chassis V16 Need service Manual
richf
Jun 12, 2012, 3:00 PM
Post #1 of 8 (3985 views)
Mitsubishi VS-50805 chassis V16 Need service Manual Can't Post
Picture goes blank but audio ok. Just before going blank shows horizontal line for a second. Turn off and after a rest will come back okay. Believe problem in Vertical, ,?cold joint. Looking for service manual or other ideas??
(This post was edited by richf on Jun 12, 2012, 3:01 PM)
Jun 12, 2012, 6:37 PM
Post #2 of 8 (3979 views)
Re: [richf] Mitsubishi VS-50805 chassis V16 Need service Manual [In reply to] Can't Post
richf;....
Here ya go....
Service Manual here;=>....
http://elektrotanya.com/...al.zip/download.html
Go all the way down to the bottom of this page to where it says;=>...
""This file is downloadable free of charge from the site: Get Manual""...
Click on "Get Manual" & away you go.....
After a closer look , this ^^^ might be a "training manual''''...
IF it is try here;=>...
http://servicetron.com/mitsubishi-2.html
Scroll down to your model number & click on it for download...
Also you can try scrolling down a bit further to VS-60805 V16N & see if that's a "Service Manual"
Please note that that manual should be VERRRY close to your set even tho it's for as 60" set & not a 50" TV as yours is...
GOOD LUCK....Sly....
Later....Ron.M....Cool....
richf
Jun 12, 2012, 10:30 PM
Post #3 of 8 (3974 views)
Re: [Ron.M] Mitsubishi VS-50805 chassis V16 Need service Manual [In reply to] Can't Post
Thanks, that exactly what I was looking for . Now to solve the problem. Hope I can find a bad solder joint
richf;....
Here ya go....
richf
Jun 17, 2012, 8:26 PM
Post #4 of 8 (3947 views)
I touched up pins connections on the Vertical Output IC. now working, If problem comes back, I will need to do the same on the deflection yoke.
Jun 17, 2012, 11:50 PM
Post #5 of 8 (3945 views)
richf;......
Just a FYI....
Deflection yokes or their connections on Mitsubishi's rarely cause troubles....
Enjoy the TV....
Later...Ron.M....Cool...
(This post was edited by Ron.M on Jun 17, 2012, 11:51 PM)
richf
Jun 17, 2012, 11:59 PM
Post #6 of 8 (3942 views)
When I googled the problem, I saw several remark that they did cause problems
I hope it is fixed as it looks like a bitch to get to the back of the pins connecting the Yoke.
Any Ideas how to touch up the connector pins if I have to??
richf;......
Just a FYI....
Enjoy the TV....
Jun 19, 2012, 5:16 PM
Post #7 of 8 (3924 views)
richf;.....
Google can & often does bring up 1,000's of listings...
I never said they do not cause problems , I said they rarely cause a problem....
I went thru my manuals looking for a pix of the yoke connectors...
I could not find any....
IF & when you need to do those connections , I would appreciate a pix of the side by side connectors...
Let's cross that bridge IF & when you get to it...
Until then , think positive & enjoy your TV.....
Have a GREAT day & week....Sly....
Later...Ron.M....Cool....
(This post was edited by Ron.M on Jun 19, 2012, 5:17 PM)
richf
Aug 1, 2012, 11:39 PM
Post #8 of 8 (3582 views)
The problem has returned I believe it is the connector on the center tube yoke. As I can wiggle it and cause the problem
[Help the connector is completely cover with a plastic shroud Is there a way to remove it???\
Any Ideas??
