Need help please 50" Zenith shuts off.....
mrbmp
Nov 6, 2004, 11:21 AM
Post #1 of 3 (596 views)
Need help please 50" Zenith shuts off..... Can't Post
 I need help on a 50" Zenith Inteq TV.Model no. IQB50M90W
It keeps shuting down.
There are about 6 leds on the board, when unit is first plugged in, 5 of the leds light and the 6th comes on when the power button is pressed, if the TV turns on it will stay on for a few seconds to an hour or so then shut off and all the leds go out. If I unplug it for several minutes it will reset and the 5 leds come on again until the power button is pressed, sometimes it shuts off instantly, sometimes it works for an hour or so.
Is there a common problem with this TV?
Ideas where to start?
Thanks for your help
val
Unregistered User
valtron@juno.com
Nov 7, 2004, 9:40 PM
Post #2 of 3 (585 views)
Re: [mrbmp] Need help please 50" Zenith shuts off..... [In reply to] Can't Post
you have a problem with the Deflection board. Those
boards are running hot right out of the manufacture.
YOu need a new Deflection. YOu spend money on
that board, its going to go out on you because of the
excess of current,or hear. spend between 100 300.
for a new board. your better of.
mrbmp
Nov 12, 2004, 1:03 PM
Post #3 of 3 (570 views)
Re: [val] Need help please 50" Zenith shuts off..... [In reply to] Can't Post
Where is this board located in relation to the main board with the A/V jacks?
Where is a good place to buy one of these?
