streetchariot
Jun 5, 2007, 6:54 PM
Post #1 of 22
(815 views)
New Issue: Philips 52UP56 Pin Cushion Problem all three tubes
I know you may say, "Why are you even bothering with this 11 year old TV?" The reason is, that I like repairing things, it's a hobby of mine. Now for the issue at hand. 52UP56 Philips-Magnavox Rear Projection TV powers up, has no picture, but rear filaments do glow on all three CRTs. (RGB) Upon turning the unit on, I can hear a low hissing sound at / around the FB-XFMR, and there is zero to little voltage measured from the Flyback to the Focus/Adjustment plate mounted in the back of the cabinet. I cannot check for sound, as this chassis has no speakers or outputs. When I hooked up RG6 cable, the hiss was variable, as if it was adjusting for changing picture. If the Flyback has 0.00 to 0.05 volts during operation, should the Flyback be suspected first, or a cap, or a resistor? All of the boards look to be in good shape for their age. All three of the CRTs are is good overall shape, and do not appear to be cracked or damaged. Please correct me if I am wrong in my assumption, but it seems that the issue with this unit is the Flyback Transformer. All of the other TVs I have worked on have had the focus adjustment built into the Flyback, but this unit has a seperate unit for adjusting focus. Thanks, Andrew
(This post was edited by streetchariot on Jun 20, 2007, 7:20 PM)
