PIONEER SD-P4682 TO MUCH RED??
boatman355
May 25, 2008, 1:39 PM
Post #1 of 6 (191 views)
PIONEER SD-P4682 TO MUCH RED?? Can't Post
i am trying to fix my friends projection set!! he is out of work and has 2 kids and this is only tv they have. so can any one help, please?? it turns on and works but has alot of red and is a little blurry?? is this an adjustment problem or a part problem? if it is an adjustment what and how do i adjust it?? also i know it is old, anyone have an operator manuel for it?? i have done some newer repairs to projection tv's before so i am not a total dumby!! please help A.S.A.P. THANK YOU BOATMAN355
(This post was edited by boatman355 on May 26, 2008, 8:44 AM)
TVRE
Jun 3, 2008, 6:37 PM
Post #2 of 6 (161 views)
Re: [boatman355] PIONEER SD-P4682 TO MUCH RED?? [In reply to] Can't Post
Did you try to regulate the TV from the HV Splitter?
It may also be time to replace the CRT coolant.
boatman355
Jun 8, 2008, 12:00 PM
Post #3 of 6 (152 views)
Re: [TVRE] PIONEER SD-P4682 TO MUCH RED?? [In reply to] Can't Post
Hi TVRE!! thanks for the response, but as i said i dont have a manuel for this set and have no idea where the splitter or coolant is ?? i have done some work before on newer sets like this, but only with manuel in hand!! also how do i get into setup mode with remote?? any and all help is very appreciated!! thank you for your help and i hope you can answer these questions for me!! boatman355
Repair man
Jun 9, 2008, 3:31 PM
Post #4 of 6 (146 views)
If there is too much red, it could mean you are missing on of the other colors like blue or green. You might be able to adjust these using the screen control block. You can find the screen & focus controls usually behind the front speaker grill then behind a removable cover. Once there you should be able to see the neck of the tubes. Often off to the left or right of the tube area you will see a focus / screen control block. There will be 6 controls on it; 3 control the amount of screen voltage & 3 are for focus (they sometime put black tape over these controls that you will have to remove). You can use these to control how much Red, Green & Blue as well as focus for all three. Once you find these controls, try adjusting them & see if you can change each color, if so then before adjusting them any more, use your remote & go to the color menu on your TV & set the color setting to as low as it will go (you should see a black & white picture) also set the brightness to approx. half. Now slowly adjust the screen controls one at a time until you get a perfect black & white picture. If you turn them to high you will start to see retrace lines, if so, back the controls off until you see no retrace. Once you see as good of B&W picture as you can, go back to your color settings & adjust the color & brightness back up to desired taste. Once color is where you like it you may want to adjust the focus for each color using the same focus block -- Dan
________________________
Learn LCD / Plasma TV Repair
boatman355
Jun 18, 2008, 6:39 PM
Post #5 of 6 (131 views)
Re: [Repair man] PIONEER SD-P4682 TO MUCH RED?? [In reply to] Can't Post
hi dan, and thanks for all your help!! i did what you said but still have a problem with red?? when i get to convergence mode to adjust the outer settings it either wont adjust or it is very crooked compaired to the green and blue and i cant get it to adjust any better ,, the red looks on screen in some places like it is going down hill or wavy!! is this the convergence board?? if so where is board in set and where do i get one?? if not what do i do next?? i will say what you told me to do with the ste has improved it greatly but i still need to get the red to adjust>???? please advise!! thank you mike
Repair man
Jul 22, 2008, 9:26 PM
Post #6 of 6 (74 views)
It sounds like you need to replace the convergence ICs. If it is a Pioneer they will probably be STK392-110. There are usually 2 of these ICS, One will be for red and one for blue, it's best to change them both while you are that far into the repair, if you don't, you will get one replaced and the 2nd could go soon. These ICs are the biggest ICs in the TV and will be mounted to large aluminum heat sinks. They usually have approx. 15 pins each.
You can get them at www.electronix.com for around $6 each. Anyone with de-soldering skills and soldering skills can replace these ICs.
Once you de-solder them and unbolt them from the heat sink, they will often be stuck to the heat sink (this is just due to the excessive heat these ICs reach) You may have to give them a tap with a small hammer to break them loose from the heat sink. Make sure they are completely de-soldered before applying too much force to remove them or you could damage the print on the circuit board making it impossible to repair.
There will be a heat sink grease between the IC and the heat sink, try to keep as much of it as you can and apply it to the new ICs. It's white in color; this heat sink grease helps the ICs to dissipate their heat to the heat sink which helps extend their life.
These sets often have an entire metal box that pulls out of the set keeping the entire chassis & tubes etc. together. Once removed you can turn this metal cage on it's side & get at these IC's from there.
To do this, there are 6 bolts to remove, 2 at the back end of the chassis, 2 more slightly down each side going through the metal and into the bottom of the wood cabinet and 2 more in from the front of the set behind the speaker grill.
You will also have to unplug the speaker wires from the chassis as well as the front buttons. Then the metal cage, housing the electronics of the set, can be slid out the back of the TV.
If you have any other questions please ask -- Dan
