Rockstar
Aug 4, 2010, 11:27 PM
Post #7 of 8
(5215 views)
Re: [starvnmarvin] Philips 60in projector tv Green Convergence Problem
I would say don't count out the convergence IC's yet, They could be Intermittent. I had the same if not simular problem you are saying but with my Samsung HCL4715W, That was warped and shakes and after some time running it, it work fix it self, but mine was the top and button left side. This how i figured it was Intermittent the IC's. With back on till it fixed itself, then take back off once it fixed it self. I used a fan to blow on the IC heat sink and it would mess up again, And I let it heat up and it fixed itself again then cool it down again and it messed up again. You could give that a try and see if it acts like mines did, Make sure you try to get most air on IC Heat sink so you don't cool something else down and make it look like it was the IC's when it could of been some other part. If it acts like mine most likely it could be the IC's.
