Phillips 7P6035W101 Snap then smoke
Guest
Unregistered User
bsma.bob.n@tir.com
Aug 16, 2004, 7:21 PM
Post #1 of 2 (393 views)
Phillips 7P6035W101 Snap then smoke Can't Post
I have a Phillips Mangnavox 7P6035W101 60" rear projection TV. Last night it made a large snap noise and went blank. A few seconds later smoke started coming out of the rear. If I try to turn the unit on, it will attempt to com one and then shut off. Any suggestions on components to investigate? Also, if I change the 'Large Signal Board' what are the odds that the problem will be corrected?
Thank you,
Bob Hiller
Guest
Unregistered User
bsma.bob.n@tir.com
Aug 18, 2004, 8:40 AM
Post #2 of 2 (383 views)
Re: [Guest] Phillips 7P6035W101 Snap then smoke [In reply to] Can't Post
UPDATE - I have found where the burnt smell is coming from. It is not the main board as I thought. It is a black box about 4 sq. in. that has 2 red, 2 blue and 2 green wires coming into it. These go to the 3 Guns R,B,G. What is this box called? Is it repairable?
Thanks,
Bob Hiller
