Oct 17, 2010, 7:46 PM
Post #7 of 9
(3270 views)
Re: [quantass] Pioneer - How to CLEAN lens?
quantass;.... When you say that the coolant ""appeared to have lots of debris floating in it as if someone blew dust within the liquid.""" , do you mean to say that the coolant is "cloudy" in appearance ??? DID all 3 CRTs look that way ??? The CRT face image was viewable but didnt appear perfect -- it seemed grainy / rough but maybe this is due to NTSC or cable signal?. IF you are in the US , ALL chans are NTSC & it's NOT the problem.... Your cable signal could be causing a grainy/snowy pix.... Was the pix in focus clearly on the CRT face ??? You should see very thin clear horizontal lines in the pix....Did you ??? I'm wondering if physical calibrating of the color lens (there is a wing nut in front that when loosened allow you to move the lens left-right), I hope you didn't turn the lens in any direction... & adjusting those is NOT needed unless you change the CRTs themselves.... Make sure those wingnuts are tight & did NOT move.... I know you have the service manual.... A STRONG piece of advice;.... Do NOT go into the factory menu for ANY reason without expert guidance... You can adjust the wrong thing & NEVER get it back the way it should be.... Do NOT adjust Factory menu Convergence adjustments...NEVER NEVER NEVER !!!! Do NOT tinker with ANYTHING before asking what you want to tinker with... You can screw it up big time...ASK FIRST.... Can the coolant be cleaned or CRT image improved? NO , IF bad , it HAS to be replaced... Which brings us to this... Based on what I've read here , I think changeing the CRT coolant "may" be beyond your expertise.....Is it ??? One more thing to check; The convergence.... Are the colors lined up where they should be ??? Do you see red , green or blue outlines around the images or wording ??? A good way to see that quickly is to bring up the menu & check the graphics for a 3D type screen.... Please answer all my questions.... Let me know the results....THANKS..... Later....Ron.M...... Veteran & Retired TV technician
