Pioneer SD-P4565 convergence problem
Guest
Unregistered User
Jul 8, 2004, 12:47 AM
Post #1 of 3 (1532 views)
Pioneer SD-P4565 convergence problem Can't Post
I recently recieved a pioneer 52" projection TV for free, because, well, it has issues. The screen would bounce some, which turned out to be a simple dirty potentiometer , the one that adjusts picture width. The problem I am having now is with the convergence. Please bear with me, I have never adjusted a projection TV before. I did find out how to get into the convergence menu, but it only allows you to adjust the red and blue guns. The green one is what really needs to be adjusted. At the bottom of the screen the green is fine, but it stretches upwards in the top corners. There is a smooth arc across the top of the screen, and its only green. I can cover the green lens, and get the red and blue to line up correctly, just not the green. Is there some hidden adjustment for this, or is it something wrong with the TV?
MaierTV
Jul 17, 2004, 6:35 PM
Post #2 of 3 (1495 views)
Re: [Guest] Pioneer SD-P4565 convergence problem [In reply to] Can't Post
When the Gods designed projection set they needed a refrance for all colors to line to some one desided Green ( Makes sence since most of the color in sets is green, ) It is usaly non adjustable by the custmer,, , If you have convergance issues and the culpret is a Pioneer ( since we dont have a model number to work wit well cover all of them,
1st one behind the speaker grill behind the panel there is a board it has one huge Ic STK4277 change that
2nd with the back removed there may be a board on the left that stand up, on this there may be Two Ic's ( STK392-110) or there may be three ( STK392-010) chang all of these
there may be two or three Ic mounted to the left ( Signal ) board STK--- change those
always change all at the same time heres why
if theres ony two they share the greens convergance, if theres three they only do one color each but they all wear at the same rate if ons gone usaly the others are right behind it
JONMC
Mar 8, 2005, 5:49 PM
Post #3 of 3 (951 views)
I ALSO HAVE A PIONEER WITH COVERGENCE PROBLEMS. IHAVE TO COVER THE GREEN LIGHT ALSO FOR IT TO GO AWAY. THE ONLY THING DIFFERENT IS MINE BOW IS ON THE BOTTOM.
DID YOU GET YOURS FIXED IF SO HOW.
THANKS JONMC
