Pioneer SD-P5053 picture problem
jschuholz
Mar 11, 2007, 10:39 PM
Post #26 of 39 (1154 views)
Re: [jschuholz] Pioneer SD-P5053 picture problem [In reply to] Can't Post
Mike,
update - when I slid the deflection board out - a 4 pin connector came off (near front of tv) - re-installed this and sets tubes come on. I have a red convergence problem - the red gun has a moon shape on the cross (manual convergence screen). I'm assuming i need to replace stk's and check resistors, caps, and solder joints around these chips. Red, blue, and green guns have a sharp focused picture - just out of convergence. Am I on the right track ? Please update on service manuals when U get a chance - I did find a site that sells them but they have several suffix's on this model ? 5053-K, 5053K, 4053K, 4053-K and they all have different prices ? Don't understand. THanks, John
jschuholz
Mar 12, 2007, 12:07 AM
Post #27 of 39 (1153 views)
Re: [mfavitta] Pioneer SD-P5053 picture problem [In reply to] Can't Post
follow up - forgot a connector on front of set - have red convergence problem. I need convergence schematic and also service manual for re-alighnment. Will have to replace stk ic - noticed 220 ufd caps are corroded - fixed this but still doesn't work - probable need to replace these also. Thanks, John
mfavitta
Mar 12, 2007, 3:51 AM
Post #28 of 39 (1152 views)
First thing to do is check every connector you disconnected and those you think you didn't. Disconnect and reconnect to make sure they are seated properly. Possible, but very unlikely it's anything else if you have been reasonably careful with the capacitor replacement.
jschuholz
Mar 12, 2007, 1:26 PM
Post #29 of 39 (1143 views)
Mike,
U must have missed my follow-up - I did miss a connector. THe set does exactly the same thing. I missed the top of the thread where the set was having black line across the bottom. My set has a red convergence problem. I cna adjust it manual from the front panel but not enough to align ot with the blue, green crts. The convergence board (behind front panel in front of tv) has some bad solder connections where the 220 uFD caps are - fixed these but to no change in pic. To fix this I need the service manual, also what R all those pots on this board for ? Do U think the STK is bad - I thought when these are bad, the convergence can't be moved at all. John
mfavitta
Mar 14, 2007, 12:18 AM
Post #30 of 39 (1138 views)
I'm not a "TV tech", just an electronics hobbyist with no formal training.I do have the manuals - You need APR2273 the SD-P4053-K manual that covers all the common circuitry and fucntion in the model line. I also have APR2285, the manual for SD-P5053-K and others, for stuff that is different than the SD-P4053-K. Alignment is in the SD-P4053-K manual. Here's the rub, much of the manual is 11*16 sheets, hard to copy or scan... You need about 16 pages of the adjustment section plus who knows what schematics and drawings.
jschuholz
Mar 14, 2007, 1:29 AM
Post #31 of 39 (1136 views)
Mike,
Think the best avenue here is for me to download the p4053 manual (on user-manuals.com). Is there any thing I would need in the P5053 manual ? If so -- is it possible to copy those ? I definitely need the convergence board layout, schematic, and how-to manually adjust convergence. Owners manual would also be nice. If yours are not duplicable, let me know. If U can duplicate them - let me know how much it would be. Thanks, John
Have a feeling that the electrolytic caps (about 10) on this board are probable bad (solder joints don't look good). I'm going to replace them and then the stk IC.
mfavitta
Mar 14, 2007, 11:42 PM
Post #32 of 39 (1130 views)
There isn't a whole lot in the P5053K manual, but if you find something missing or different. I'll try to scan and send.
jschuholz
Mar 16, 2007, 1:14 AM
Post #33 of 39 (1127 views)
This morning purchased a p4053 manual from user-manuals.com. Unfortunately they took my money and no download. Must be an offshore outfit. They do not respond to emails I've sent them. Do U have a good contact for service manuals ? Thanks, John
jschuholz
Mar 23, 2007, 12:46 AM
Post #34 of 39 (1110 views)
Replaced stk4277 for nothing - I have red pin cushion on top and bottom of screen. Replaced all electrolyte caps on deflection board. check resistors, checked solder joints. just got P4053 service manual - not that best prints - hard to read. anyone have any ideas ? Thanks, John
nitro3232
Jun 3, 2007, 11:51 AM
Post #35 of 39 (922 views)
Re: [dmoo2] Pioneer SD-P5053 picture problem [In reply to] Can't Post
Could you also send me the schematics and any pictures with that. Niroca@muohio.edu. Thank you
pipsqueek
Jun 12, 2007, 11:40 PM
Post #36 of 39 (855 views)
Can someone send copies or jpgs of schematics for the Pioneer to atoy@shaw.ca. Thank you.
brizzo320
Jun 16, 2007, 2:24 AM
Post #37 of 39 (810 views)
Re: [pipsqueek] Pioneer SD-P5053 picture problem [In reply to] Can't Post
Just bought an old Pioneer SD P5053 today and the screen needs to be cleaned. What should I do to do this, is there a way to take it off and what should i clean it with? Any help appreciated.
rlhull
Jun 17, 2007, 7:03 PM
Post #38 of 39 (768 views)
Re: [nitro3232] Pioneer SD-P5053 picture problem [In reply to] Can't Post
Can you please send me a copy of the schematics also and any pics you might have thanks to rlhull357@yahoo.com
Joseph Chien
Jun 19, 2007, 2:13 AM
Post #39 of 39 (749 views)
Re: [rlhull] Pioneer SD-P5053 picture problem [In reply to] Can't Post
My old #5053 had same vertical problem,Can you please send me the pics and schedmatics and manul to to manually adjust convergence thank you cnkingfu@yahoo.com &lt;br&gt; <br>
(This post was edited by Joseph Chien on Jun 19, 2007, 2:17 AM)
