Pioneer SD-P5181-K Picture loss after warm up
willwatsonfl
Oct 12, 2007, 9:48 AM
Post #1 of 5 (235 views)
Pioneer SD-P5181-K Picture loss after warm up Can't Post
This is going to be the last fix for this unit before it goes to the curb. I bought this tv new and have only had 3 problems. I loss the convergence board in 2003, blew 1 transistor on the green gun PCB 6 months ago, and now I think the FBT might be going bad. With all that said, here's what I've got.
After leaving unplugged all night, I plug the unit in...Everthing works great...Sound, Picture, Inputs. After about 20 minutes the picture goes black and the sound gets slightly louder (with whats sounds like a little white noise mixed in). This leads me to believe that it has some kind of power issue after warming up. Now I've seen Flyback transformers start going bad that would cause this, but reading all the other posts...some people point to the convergence IC's.
After I get home tonight I'm opening up the unit to get a better diagnosis. I found the service manual in pdf that I got the first time I had problems and I'm taking my test equipment home....So if anyone has any idea or has had similiar problems please let me know. Thanks
lwinter
Dec 27, 2007, 8:08 PM
Post #2 of 5 (200 views)
Re: [willwatsonfl] Pioneer SD-P5181-K Picture loss after warm up [In reply to] Can't Post
Hey there:
I just joined the forum today and happened across your posting. I have a SD-P6081-K, which is simply a bit larger version of your unit, otherwise they're almost identical. I had a similar issue with my unit about a year ago. What was causing my problem and what could be the source of your issue is a cold solder connection somewhere on the under side of the board. Although that line of Pioneers was of really high quality in general, they did have a recurring issue with soldered connections on the boards being poorly made. That resulted in connections developing microscopic breaks over time that often caused intermittent symptoms to appear; one minute the unit seemed fine, the next it was behaving oddly. The symptoms sometimes appear when the set is turned on and then go away after things have warmed up; other times the set will function properly only until the components have warmed up, and then it goes haywire. Thermal expansion of the boards/components/connections appears to be the most agreed upon cause for this.
I fixed the problem on mine by removing the board the flyback is mounted on so that I had access to the underside of the board. After thoroughly cleaning the board with PCB cleaner, I carefully resoldered every connection with a low wattage iron, checking each under a bright lamp and magnifier before moving on to the next. In looking at each of the connections before and after reflowing the solder, I noticed several that looked "iffy" before I hit them.
Once I went through all the connections I went back and rechecked my work, and then put the board back in, reassembled everything and tested the set. It worked perfectly! No more flaking out after an hour or so of use. That was back in Jan '07 and the set hasn't missed a beat since.
The reason I went through the pain of resoldering the connections is that I found the same problem on the convergence board when the STK4277-SL IC went bad. I replaced the chip, which corrected some of the problems, but I still had intermittent issues that would just go away after the set had been on for about 2 hours. I remembered reading about the cold solder problem with Pioneers, so I pulled the board again and reflowed every single connection. When I put it all back together; no more problems.
I'm not a TV repairman by trade, but I am an electrical engineer, so I guess I have some qualification in recommending this (potential) fix, aside from the obvious real-world experience I have with this set. The next time I have a problem with it, especially if it's intermittent or comes on suddenly, the first thing I'll suspect is a solder connection somewhere else I haven't touched yet (which isn't very many left!). Hopefully my set will hang on another year or so; once the conversion to digital signals is completed and the rush to buy new flat panels is over, prices on them should drop even more, not to mention that the picture quality will do nothing but improve as the technology matures and advances. :) Bet my next set is not only far superior to this one, but it'll probably cost less too!
I hope this helps!
Len
PS: Where did you run across the PDF of the SM? I haven't seen that anywhere online and have been looking for one.
willwatsonfl
Dec 28, 2007, 7:48 PM
Post #3 of 5 (194 views)
Re: [lwinter] Pioneer SD-P5181-K Picture loss after warm up [In reply to] Can't Post
I thought I had posted after I fixed the set a couple of months ago, but I guess I didnt. There was actually 2 problems. The first was bad solder joints on the flyback transformer (and I do mean bad). Hardly any solder and 3 spots had cracked. After that fix, the colors were all out of wack so I replaced the STK-4277 IC on the convergence board. Every thing has been working for the last few months, but I have 2 small lines that appear on the screen. You dont really notice them, but it is still annoying. Anyway, I'm not going to open the TV back up unless something major fail again.
Hope this post helps someone else in the future...Will
lwinter...I got my service manual from http://www.manuals-in-pdf.com/. It's only for the 5181 and 4181. Your model is close, but not exact.
lwinter
Dec 28, 2007, 10:10 PM
Post #4 of 5 (190 views)
Hey Will, I'm glad you were able to fix your set and that it was as simple a fix as it was. I haven't the faintest idea what could be causing the lines you mention, but if they're not totally annoying I agree; unless something else major goes wrong, leave well enough alone!
Thanks for the link to the manual site. I did a bit further checking and the SDP5181K manual is the same one for the 6081K; their chassis are the same, basically just a bigger cabinet. There is a supplement specifically for the 6081K, but I'm told it has nothing that's all that relevant to board repairs. Pioneer no longer has the hard copy of the main manual, and the only site that does wants $99 bucks for it, exactly twice what Pioneer originally charged. Guess they know they have you cornered if you want the original. I'll settle for the PDF for $14.95! If I feel the need for real paper, I can always print it out. :)
Thanks for responding; these are great sets and with a little putting our heads together and sharing our experiences, we can keep them going for a few years longer.
~Len
willwatsonfl
Dec 30, 2007, 8:34 PM
Post #5 of 5 (161 views)
Hey lwinter...if you shoot me an email...I can help you out with that service manual...WW
