cfox
May 3, 2005, 12:00 PM
Post #1 of 3
(1401 views)
Pioneer SD-P55A5K Dead As A Door Nail
This set is 8 years old, it has had prior problems with convergence. It has also had many problems with loose solder connections on the power side of the board. Over the weekend I went to turn the set on, it acted like it was going to come on but then went back off. I pulled the back off, and checked all fuses on the power side of the board, they all seem to be fine. On the front of the set I used to have a red standby light that was on all of the time, until I turned the set on, and then it would turn to green. Now I have no light at all, red or green? I had a so called tech out to look at it, and he again checked all of the fuses with no bad ones found. His soultion was the convergence chips needed replaced, the set was in shutdown mode. My question is how could this set go from playing great with no convergence problems at all, to now needing the convergence chips replaced? Does this tech know what he is talking about, or could there be something else causing this problem? Thanks
