Pioneer SD-P4681-k
h_bomb41
Unregistered User
h_bomb41@yahoo.com
Jun 20, 2003, 8:17 AM
Post #1 of 8 (3278 views)
Pioneer SD-P4681-k Can't Post
Convergence problems with the blue. What do I do to correct this problem? Any suggestions would be greatly appreciated.
MaierTV
Jun 21, 2003, 6:00 AM
Post #2 of 8 (3256 views)
Re: [h_bomb41] Pioneer SD-P4681-k [In reply to] Can't Post
Remove the speaker grill then the panel behind that you will find a board mounted to that panel find the big ass Ic ( STK4277 ) and change it,
problem solved almost every timeAngelic
royp4
Sep 1, 2003, 4:43 PM
Post #3 of 8 (3110 views)
Re: [MaierTV] Pioneer SD-P4681-k [In reply to] Can't Post
I too have a convergence problem with a pioneer rear projection tv (sd-p5193k), even after replacement of the convergence board. Is there a way to enter the setup menu, and is this what I need to do ? Any information you could provide will be most deeply appreciated.
Thank you,
Roy Parnell
royp4@aol.com
Guest
Unregistered User
Jan 6, 2004, 11:48 PM
Post #4 of 8 (2958 views)
Re: [MaierTV] Pioneer SD-P5183-k [In reply to] Can't Post
I HAVE THE SUBJECT TV.
PICTURE COMPLETELY GOES OUT AFTER ABOUT 2-3 HRS.
BEEN GOING ON LIKE THIS FOR A MONTH OR SO.
NOW THE PICTURE WILL NOT COME ON AT ALL, AUDIO IS GREAT.
ANY IDEAS OR SUGGUSTIONS WOULD BE APPRECIATED
Denny Denny.C@comcast.net
Guest
Unregistered User
cyb00@yahoo.com
Feb 26, 2004, 6:24 AM
Post #5 of 8 (2898 views)
Your suggestion to replace part STK4277 was a lifesaver.
Essentially, I got myself a new TV after replacing the part.
Thanks, suggestion was right on.
Guest
Unregistered User
waynejohnston@statesville.net
Feb 27, 2004, 11:38 PM
Post #6 of 8 (2890 views)
Re: [Guest] Pioneer SD-P4681-k [In reply to] Can't Post
I have a problem with this same set sd-4681-k, when I first turn it on the picture is sort of out of focus and the picture is convave somewhat the convergance is way off as the set heatsup it corrects and looks fine if I leave the set on it looks great, the problem is only during warmup, is this a convergance board problem as well? if so is the board mounted on the panel under the grill the convergance board. Thanks for any help
Guest
Unregistered User
rolandsalvador@hotmail.com
May 14, 2004, 9:16 PM
Post #7 of 8 (2754 views)
Hi I have a convergence problem with my Pioneer SD P4681K. Can you tell me again how to correct this problem? What exactly is the speaker grill?
Thanks,
Roland
Guest
Unregistered User
Jun 17, 2004, 5:23 PM
Post #8 of 8 (2625 views)
the speaker grille is the mesh part in front of the speakers at the bottom of your projection TV.
if you need a place to find that part here a link:
http://www.partsolver.com/Product.asp?InventoryID=13040810&SubstitutePart=1&OrgPartNum=STK4277&OrgPartMfg=Pioneer
