rborge
Sep 20, 2004, 5:01 PM
(461 views)
Please help me ID these parts.
I have a Toshiba 50H82 rear projection tv. My son cracked the screen with a baseball. So I took it apart... There are 3 "sheets" that make up the screen. The outer sheet appears to simply be a plexiglass layer for protection. It is cracked.. no problem. Behind the plexiglass is a tinted sheet that is also cracked. Behind it, is a clear (but frosted) sheet with a serrated surface. It is intact and does not need to be replaced. My question is simple: What is the correct name for the tinted sheet described above? This will help me order the proper part. Thanks Rick
