Apr 21, 2010, 8:45 PM
Post #7 of 11
(6842 views)
Re: [ryan42] Problems with Phillips Projection TV - Missing Blue
ryan42;.... shoofeetv is an IDIOT ... Ignore him/her/it.... For the green focus problem;... Check BOTH ends of the red wire going into the green CRT socket for good secure connections... You said;=>..."""I can't converge blue"" We'll get to that one later.. Can you take & post pix ??? I may need to see certain areas... """One thing I'm concerned about is the HV retaining clips as I had to make new ones because the old ones just fell apart. If that wasn't making good contact I wouldn't have any picture at all though, right?"" NOT neccessarily....I need to see what you mean by;>""I had to make new ones"" """"I was not able to, as the instructions say, converge red then use it as a reference for the "physical" convergence of the blue because I was unable to see red at all on the screen.""" Something is NOT right with that statement !!!...The green convergence is FACTORY SET..... After you change the coolant , you converge the red & blue to the green CRT.... Usually all that is needed are touch-up adjustments... You do NOT use the red (OR BLUE) for ANY references.... If you are missing a color , do NOT do convergence adjustments.... As for the manual;... My email service can handle the manual with no problem...... However....NO OFFENSE , NOTHING PERSONAL , BUT , I'm leary of giving out my email address to ANYONE...... Has to do with all this money the Nigerians are sending me....... Don't want to screw that up....Yeah..Right.... What is yousendit.com & how does it work ??? If it's like boxstr , no problem.... Later...Ron.M....... Veteran & Retired TV technician
(This post was edited by Ron.M on Apr 21, 2010, 8:47 PM)
