CALVINPROCTOR
Feb 18, 2004, 12:14 PM
(1013 views)
Re: [ourbudd] RCA 46? how to get crosshatch for convergence adjustments
You would need a signal generator for crosshatch unless you know someone who has one -- In that case, take a VCR, record the signal, take the tape home and play it on your set -- However, to make fine adjustments on convergence, you will need to enter the service menu and change the parameters around -- difficult to do without literature and you can really mess things up in there if you aren't familiar with it -- I shut a set down one time messing around when I first went into business and had to change the Eeprom to get it working again -- and that was a mess.... As for the tuner, if the set is to your satisfaction other than the snow, I would replace the tuner, if you are sure this is the cause of your problem -- p/n 203533 runs about $52.00 from Tritronics.... Or, there again, if you have a friend in the biz, they might have a junk chassis with a good tuner (cheap!) Calvin
