RCA P46730 will not power up ......
jdgoulden
Oct 19, 2004, 6:07 PM
Post #1 of 2 (726 views)
RCA P46730 will not power up ...... Can't Post
Hello all, I'm having trouble with a RCA P46730WK television that just recently gave up the ghost. The television will not power up either from the remote or the switch on the front of the television. After checking that all the obvious causes were absent I removed the back panel of the television to check for fuses. I found only one glass fuse near the plug connection on the main board that checked OK with a meter. I also noticed that there was a resistor R126U that was located on the main board that had corroded and fallen apart. Yeah I said corroded, apparently they soldered 2 resistors in series at the factory and where the two resistors (that appear to make up this one labeled resistor?) were joined above the board they had come apart. Unfortunately I can't tell what the value of the resistors are, because they are painted, or insulated with a dark plastic material. Can anyone tell me what the value of the resistor is? I don't have access to a schematic, but I would suspect that if the actual problem is just that resistor, I should be able to insulate the leads with a piece of heat shrink, and solder a new one in place. Any help would be appreciated greatly, TIA.
Jay
Unregistered User
sydewinder99@yahoo.com
Oct 29, 2004, 12:26 PM
Post #2 of 2 (698 views)
Re: [jdgoulden] RCA P46730 will not power up ...... [In reply to] Can't Post
Tia,
R126U does not show up in PartsFinder for that model. The only resitor I find with a 126# is R4126 which is a 6.8 ohm 5% 3 watt or RCA# 206016. hope this helps. Jay
