95yj
Sep 29, 2005, 10:47 PM
(1814 views)
RCA P56926 Front Panel Connections
I have an RCA 56" rear projection TV, model P56926. The cabling between the front pannel (menu ch- ch+ vol- vol+ power) and the main board and also between the speakers and the main board have been disconnected. There is a set of 5 wires running from the front pannel that ends in a female 7 position connector. There is also a set of 7 wires running from the main board that end in a female 8 position connector. It looks as if there is a pigtail with a 7 position connector on one end and an eight position connector on the other that is missing. The set of cables from the front panel are tagged with P3407 and have 4 black, 1 blue, 2 empty from left to right. The set of cables from the main board are tagged with P13408 and have 1 black, 6 white, 1 empty. Printed on the main board by the connector are two number J13201 and JW12194. The speakers can probably be figured out by trial and error. From the speakers the cable is a 4 position connector tagged P13401 with blue, black, black, brown comming respectively from R+ R- L+ L-. The cables from the main board are labled P11901 and have 3 white, 1 black. Both of these connectors are 4 position female. The connector on the main board is not labled. Does anyone have a wiring diagram telling how to hook these back up or know how the pigtails would be wired? Taking the unit in for service is not an option as it is now in Aruba and there isn't really anyone down here who does this.
