Aug 13, 2010, 7:42 PM
(1130 views)
Re: [sunnyguo] RCA Projection TV P61926
sunnyguo;..... Could be either one....HV Splitter OR Flyback.... It would help if we had a chassis # posted.... My suggestion would be to replace the HOT first , (get extras).... Then with your eyeballs glued to the Splitter , turn on the TV & see if you see any arcing to chassis ground or wisps of smoke in the area.... Be ready to INSTANTLY jerk the AC cord from the wall outlet as SOON as you see arcing or smoke.... You more than likely will blow the new HOT out doing this test... Another way to do this (Somewhat more sane) would be to disconnect the HV lead that comes from the flyback to the Splitter at the Splitter.... There is a small tab that you gently bend away & pull from the wire at the top where the HV wire goes in to the Splitter... Dangle the wire as FAR AWAY as possible from ANY metal OR other wiring OR components.... This wire WILL have 30,000 volts on it when you turn on the TV.... It WILL knock you on your @$$ &/or cause dammage to the set..... After you have the wire SAFELY hanging in space , turn on the TV.... IF it stays on & does NOT blow the HOT , chances are that your Splitter is bad.... If you blow the HOT , chances are that the flyback &/or associated circuitry are involved... GOOD LUCK........ Later...Ron.M......... Veteran & Retired TV technician
