Repair man
Nov 24, 2012, 6:06 AM
(1914 views)
Re: [BobS] RCA R52WM24 Convergence Problem
Check the 2 flat ribbon cables that link between the signal board & the board with your flyback on it to make sure they are seated properly. Also, there are 3 small fuses near the flyback, sounds like you maybe replaced 1 of them, check the other 2 to see if they are open, could be one of them. There are also at least 2 more fuses like the small rectangular ones near the flyback that are located on the signal board, one is near the tuner & the other is out in the middle of the signal board somewhere, check those fuses as well. Other than that there are a bunch of caps that go bad on the board with the flyback, I can send you a picture of what caps to change if the above steps don't work. . ------------------------------------------------------------------------------------------ If you (or anyone reading this post) have any further questions or need clarification please feel free to contact me direct; you can find my email address by clicking on my user-name. Learn Plasma TV Repair _________________ Learn LCD TV Repair
