Remove cables from HV Transformer
RA
Jan 5, 2007, 12:08 AM
Post #1 of 6 (183 views)
Remove cables from HV Transformer Can't Post
I have a Toshiba 61H71 and need to remove the power supply so I can ship it to PTS Corp for them to repair.
I have disconnected everything but I cannot figure out how to remove the cables from the HV Transfomer, these have rubber boots going onto the ports on the HV transformer, is it just pull off or is it more complex.
Also how would I fit them back on once I get the board back after repair, appreciate your advice.
Please see attached photograph. Cables with the rubber boots
Thanks
Attachments: DSC04731.JPG (1.55 MB)
Jan 5, 2007, 6:05 AM
Post #2 of 6 (178 views)
Re: [RA] Remove cables from HV Transformer [In reply to] Can't Post
flip up the rubber boots and pull the cable out.its very difficult on some to do this so careful you dont snap the board,there is a metal cap on the end of the wire that pushes into a metal cup inside the transformer. mark where each goes first.
mikemaiertv
Jan 5, 2007, 8:30 PM
Post #3 of 6 (173 views)
Re: [techchris] Remove cables from HV Transformer [In reply to] Can't Post
Christ NO NO! Rubber boots up then push down and turn 1/4 turn to the left, these "unlock" if you pull them strait out you get to buy a new splitter or anode leads
RA
Jan 5, 2007, 10:39 PM
Post #4 of 6 (172 views)
Re: [mikemaiertv] Remove cables from HV Transformer [In reply to] Can't Post
Thanks for the info, that took care of the 4 on the right side (see my picture).
How do I remove and replace the thin one on the left and the other thicker one next to it, they don't come out with the same procedure.
Thanks
RA
Jan 11, 2007, 5:48 PM
Post #5 of 6 (160 views)
Please can somebody help with the cables on the left (see above).
I can't send the part out for repair without detaching them.
Thanks
Hect7369
Jan 13, 2007, 5:20 PM
Post #6 of 6 (144 views)
Look for a tech in your area,if you can't do it yourself..probably, doesn't charge much.
You will know how to unplug them in the future.
