Round 2 with the RCA PTK195 61"
First page Previous page 1 2 3 4 5 6 7 8 Next page Last page  View All
Aug 19, 2015, 4:09 PM
Post #26 of 177 (5809 views)
Re: [Misfire] Round 2 with the RCA PTK195 61" [In reply to] Can't Post
Misfire;...
On the yokes there are 2 sets of wires...
Both will have 4 wires each...
One set should have a red , blue , yellow & a green wire...(Usually)..
That set is for Horiz & vertical deflection & IS NOT the set we want...
The set we want will have thinner wires..
That set is for the convergence...
The thinner wires on the red yoke will go to the convergence board...
There are 3 connectors running along the left side of the panel , I believe...
See pix below...
The bottom connector should be "J19301" & is the connector for the red yoke..
UNPLUG the wiring that goes to that connector...
The center one , "J19302" , is for the green yoke...
Disconnect that one & PLUG the red connector into the green connection..
Plug the wires that go to the green yoke into the red connection...
Essentially what we are doing here is switching convergence circuits from the red & green to see what gives..
Turn on the TV ...
Do not worry about the convergence being out of kilter, it will be !!...
What we want to know is IF the previous red box that you had before is STILL red or did it change to green..
Please post results...
THANKS...
[URL=http://s772.photobucket.com/user/RonMa/media/Conv%20Bd%20Layout_zpsdkpiyao2.jpg.html]
Later...Ron.M...Cool...
Misfire
Aug 19, 2015, 8:27 PM
Post #27 of 177 (5800 views)
Re: [Ron.M] Round 2 with the RCA PTK195 61" [In reply to] Can't Post
what about the G,R,B jumper on small CRT board? pay them no nevermind?
Aug 19, 2015, 8:50 PM
Post #28 of 177 (5793 views)
Re: [jts1957] Round 2 with the RCA PTK195 61" [In reply to] Can't Post
First three jumpers determines the color drive that is fed to each CRT cathode. Necessary for a working set to have ONLY one of each color. Since all three CRTs are the same, usually just swapping whole boards (if wire length adequate) is sufficient for testing.
My opinion: Put 'em back.
Aug 19, 2015, 10:19 PM
Post #29 of 177 (5784 views)
Misfire;.....
PLEASE do as jts1957 said...
Put them back EXACTLY as they were...
Then do as I suggested..
Later...Ron.M...Cool....
Misfire
Aug 20, 2015, 3:59 AM
Post #30 of 177 (5775 views)
not enuff wire length to swap small CRT boards, all CRT G,R,B, jumpers are in correct location, so I swapped J19301 with J19302 to no avail, no change, red cone still there.
Aug 20, 2015, 5:10 PM
Post #31 of 177 (5752 views)
Misfire;.....
IF you really want to "Misfire" here , go ahead & continue to go off on tangents of your own & NOT do exactly what is asked of you only...
Namely;=>..
NOWHERE did I ask you to SWAP the CRT boards...
I specifically asked you to
There should have been ALL the wire length needed to do that adequately...
We are going to switch the red & green yokes next..
From the pix you have in your first post , it looks like you may have something else in the way of sliding the yokes off the CRTs..
IF so , do NOT attempt ANYTHING till I give you the go-ahead...
Please take & post a CLEAR close-up pix of the green CRT neck that is shown in your pix...
THANKS... Wink
Later...Ron.M...Cool.....
Misfire
Aug 20, 2015, 7:23 PM
Post #32 of 177 (5744 views)
I'm sorry,,, I had misunderstood jts quote as instructions to follow recommended by you first, I apologize,
http://i776.photobucket.com/albums/yy45/Misfire_photo/CAM00583.jpg
Aug 21, 2015, 12:05 AM
Post #33 of 177 (5733 views)
Misfire;...
A bit of confusion here , NO worries & NO apology needed..Smile....
I did ask for the green CRT only , however the pix is GREAT !!!
My concern has to do with the "white" thing wrapped around the CRT neck...
Please check & see IF there are ANY wires going to that white sleeve..
Look around the whole neck...
Since you are going to slide the yokes off the CRTs . in your judgment , do you think that IF there are NO wires going to the sleeve , will the yoke slide past the sleeve WITHOUT causing ANY damage to it OR the sleeve ???
(That's the LONGEST question I have EVER written !!!)
THANKS...
(This post was edited by Ron.M on Aug 22, 2015, 4:53 PM)
Misfire
Aug 21, 2015, 12:51 AM
Post #34 of 177 (5728 views)
Yes sir, on all three guns there are a white and green wire that comes from the small CRT board underneath that go's inside the white sleeve or tap rather,,,,, What's is a yoke?
Aug 21, 2015, 4:30 PM
Post #35 of 177 (5698 views)
Misfire;....
Complications , complications , damm , complications !!!..
OK..
I'm about 95% certain that I know what is wrong with your TV , but , am having a problem proving it...
We are going to mess with the RED CRT ONLY !!!..
Take a close look at the sleeve for a beginning of the sleeve's tape..
OR a shallower depression in the tape that runs from top to bottom of the sleeve..
Post observations..
THANKS...
[URL=http://s772.photobucket.com/user/RonMa/media/CRT%20Neck%20w%20Sleeve_zpscehozlzf.jpg.html]
The yoke is a transformer that deflects the pix from top to bottom & left to right..
It's full name is "Horizontal & Vertical Deflection Transformer" or yoke for short...
It got the name "yoke" from the neck collar that horses wear...
It is the device mounted directly above the sleeve we are going to somehow bypass..
Misfire
Aug 22, 2015, 6:07 AM
Post #36 of 177 (5688 views)
http://i776.photobucket.com/albums/yy45/Misfire_photo/CAM00584.jpg
Aug 22, 2015, 4:51 PM
Post #37 of 177 (5679 views)
Misfire;....
GREAT PIX !!!..
[URL=http://s772.photobucket.com/user/RonMa/media/CRT%20SVM%20COIL%20-12_zpsuv2sqb6x.jpg.html]
Just as I thought !!!..
That is a SVM (Scan Velocity Modulator)...
Get a black permanent felt tip marker...
Put lines on the glass up against the coil at the green lines...
Make lines on the coil to & on the CRT glass as the red lines show...
CAREFULLY peel the rest of the tape off & the coil should come off the CRT..
That tape may/may not be re-useable..
No worry , can be fixed later...
IF you can not get the coil off the CRT , STOP & post here & will figure out another method...
AGAIN , we ARE ONLY working on the RED CRT !!!..
Note that the word "TOP" on the coil is pointing toward the BOTTOM of the CRT...
(This post was edited by Ron.M on Aug 22, 2015, 10:37 PM)
Misfire
Aug 23, 2015, 10:08 AM
Post #38 of 177 (5664 views)
The SVM tape coil location was marked on glass and carefully removed with no damage to it,
Aug 23, 2015, 5:08 PM
Post #39 of 177 (5631 views)
Misfire;.....
OK , that's great !!!...
Now it gets tricky & DANGEROUS...]
Using the pix below;=>..
[URL=http://s772.photobucket.com/user/RonMa/media/CRT%20YOKE%20MARKINGS_zpskavgywqr.jpg.html]
The white item at the top of the pix is the YOKE !!!...
Remove the small panel (circuit board) at the bottom of the CRT..
Clear any wiring etc at & around the bottom area to allow passage of the yoke once you free it up..
Check & MAKE SURE that you have plenty of slack in the 2 sets of wiring (The red convergence (P19300 & J19301) & deflection sets , (P19104 & J19104) from the convergence board..
You will need enough slack to slide the yoke off the CRT...
Using your black marker , mark the tape against the white tabs shown in red..(The more the merrier!!..)..
Then using a 1/4" hex nut driver loosen the clamp in the green circle...
Try & twist the yoke in one direction or another & see if the yoke turns..
Do NOT FORCE the issue..
The glass on the CRT necks is very thin compared to the rest of the CRT & you can break the neck & not only will you destroy the CRT , but you can get hurt as the CRT is under a vacuum & when it implodes glass will fly in all directions..
IF it does NOT turn try loosing up the clamp some more...
IF it still does not turn , you'll need a very small flat blade screwdriver...
REMOVE the clamp from the yoke..
Note the slotted area in the center of the clamp...
That is where you'll put it back on..
Using that screwdriver GENTLY pry up each tab using EXTREME CARE...
Those tabs MAY have become somewhat dry rotted & brittle with age..
DO NOT BREAK THEM OFF !!!...
There are tabs around the other side you can not see in the pix...
USE care when you pry those loose...
IF you do that successfully , the yoke should now turn freely...
Make sure that when you do this , you hold on to the yoke so that IF & when it is freed up , it doesn't go sliding down the CRT & causing some damage or maybe destroying the CRT...
You should have enough clearance to slide the yoke off the CRT ..
At the bottom of the CRT is a socket with pins etc..
In the center of that area is either a green stem or a bare glass stem...
Do NOT under ANY circumstances break that stem..
That stem seals the vacuum inside the CRT & IF broken , you'll have a 61" doorstop or one helluva boat anchor......Pirate
BE CAREFUL NOT TO BEND OR BREAK OFF ANY PINS AT THE BOTTOM OF THE CRT !!!...
Position the yoke so you can take a close-up of the inside looking from the top down thru it..
Please post pix...
PS:...
There are 2 rings with tabs just above the clamp in the pix...
Mark their location with your marker...
Those ARE usually easy to break , so do NOT grab them or move them in any way...
IF you run into ANY glitches or problems STOP & post & we'll figure out a solution..
GOOD LUCK..Smile...
THANKS...
(This post was edited by Ron.M on Aug 23, 2015, 5:26 PM)
Misfire
Aug 23, 2015, 9:53 PM
Post #40 of 177 (5620 views)
removed clamp and marked the tabs to tape, tabs were still soft and pliable, tape gave some grief in removal but I got it off,,, seems to be wetness residue on funnel part of glass, prob from TV coolant leakage that started this chain reaction.
http://i776.photobucket.com/albums/yy45/Misfire_photo/CAM00589.jpg
wanting to add couple more fotos but photobucket must be hacked or has a web page problem,
(This post was edited by Misfire on Aug 24, 2015, 7:42 AM)
Misfire
Aug 24, 2015, 8:00 AM
Post #41 of 177 (5603 views)
http://i776.photobucket.com/albums/yy45/Misfire_photo/CAM00587.jpg <br>http://i776.photobucket.com/albums/yy45/Misfire_photo/CAM00589.jpg <br>http://i776.photobucket.com/albums/yy45/Misfire_photo/CAM00591.jpg <br> <br>must be my desk-top messing up,,, did this on my laptop, <br>
well crap,, I still cant get photos come up,,, let me know if you have any luck,
(This post was edited by Misfire on Aug 24, 2015, 8:04 AM)
Aug 24, 2015, 10:21 AM
Post #42 of 177 (5594 views)
Using the image bbcode tag you can easily post images on any site that support bbcode
http://www.bbcode.org/reference.php
Misfire
Aug 24, 2015, 2:58 PM
Post #43 of 177 (5587 views)
OK, cool, i can pull pictures now, photobucket was running sloooow and had all kind of pop-up mess going on when up-loading and retreiving HTML adress,
Aug 24, 2015, 4:38 PM
Post #44 of 177 (5575 views)
Misfire;...
WHY did you remove the tape ???
Aug 24, 2015, 5:04 PM
Post #45 of 177 (5571 views)
Just watch how big they are, use Preview Post button.
I don't see much in the way of 'marks' either.
(This post was edited by jts1957 on Aug 24, 2015, 5:09 PM)
Aug 24, 2015, 5:47 PM
Post #46 of 177 (5568 views)
jts1957;....
They're there...
He's probably got them in the trash bucket , on a kitchen table , on the floor near the TV or ???...
I need to explain to him exactly what the *%#&*@ those marks are for...
He also had a pix the CRT with a BARE neck & ALL tape REMOVED !!!!...
http://i776.photobucket.com/...e_photo/CAM00591.jpg
NOW it's BACK !!!
Later...Ron.M....Cool..
(This post was edited by Ron.M on Sep 3, 2015, 4:04 PM)
Aug 24, 2015, 6:13 PM
Post #47 of 177 (5559 views)
A highly competitive game of Tic-Tac-Toe perhaps?
Now we'll have to use the ones in your pictures.Tongue
(This post was edited by jts1957 on Aug 24, 2015, 6:15 PM)
Misfire
Aug 24, 2015, 7:12 PM
Post #48 of 177 (5552 views)
Oh no ya don't,,, the only tape i removed was for the SVM and its location was marked,,,, there was also tape under the white tabs where the clamp was where i also marked the places you had told me,,, tape was sticky where bled thru guessing,,,, thats it brotha, just as said.... also mentioned photobucket is having issues. what do i need to look for please? would wetness from TV coolant be the issue from previous problem?
Aug 24, 2015, 8:25 PM
Post #49 of 177 (5548 views)
Misfire;....
Did you remove THAT tape ???....
IF you mean "dead set" with R14703 smoking , Yes , possibly , depending on where it went to...
IF you mean the red box , NO...
Misfire
Aug 24, 2015, 8:41 PM
Post #50 of 177 (5539 views)
No sir, I did not remove that tape,,,, I did mark it to realign it back in its original position when going back,,,, only tape removed was for SVM because of wires,,,, also marked. there is a slight wetness at the funnel neck of glass, where it horn's out,, im sure it had gotten into the red coils of white part i removed,,, could that be causing the issue?
Search for (options) - Page loaded in: 0.20 s on (CGI/1.1)
