Misfire;.....
Not following instructions;=>..
Post #40;...
removed clamp and marked the tabs to tape, tabs were still soft and pliable, tape gave some grief in removal but I got it off,,,
NOWHERE did I say to remove that tape !!!
Pix;..
http://i776.photobucket.com/...e_photo/CAM00591.jpg
Then this;=>..
Post #48;=>..
Oh no ya don't,,, the only tape i removed was for the SVM and its location was marked,,,,
Either that was / is a lie or ???
Since the pix proves different result..
From post #50;=>..
No sir, I did not remove that tape,,,, I did mark it to realign it back in its original position when going back,,,, only tape removed was for SVM because of wires
So you repeated the lie ???
From post #63;->..
no blacked or carbon tracking going on other than cannot see metal holding tabs for the IN wire from fly-back transformer, and that's the one when wire is moved some the sound changes..
We need to follow up on this issue ....
From post #69;=>..
Do the other wires have a copper colored (or another color) connector with the wire coming thru the center of it & soldered or spot welded in place ??...
NO answer from you regarding this issue !!!..
From post #64;=>..
i just noticed this, think someone's been here before,
http://i776.photobucket.com/...e_photo/CAM00613.jpg
We need to check this out a bit further...
From post #74;=>..
question? This TV offers error codes in service mode, or is that not anything?
Yes , it MAY be , however we are getting ahead of ourselves & UNLESS you KNOW what you are doing STAY THE HELL OUT OF THE FACTORY MENU !!!..
From post #80;=>..
I have not skipped anything you have asked me unless something starts working properly or not making noise anymore why pursue it,,,
See above examples...
There are VALID reasons for my questions...
IF you do not answer them & give me the info I want , we're done...
If I don't post a foto is because nothing has changed.
IF I ask for one , please post it or I'll have kittens..
Now..
BEFORE we proceed...
We need to finish up on ALL the issues above...
Some rules;...
Do NOT withhold answers to my questions..
Do EXACTLY as I ask..
NOTHING MORE , NOTHING LESS !!!..
Do NOT do ANYTHING NOT requested...i.e. go off on tangents..
Understood ???...
Later...Ron.M....
(This post was edited by Ron.M on Sep 3, 2015, 5:00 PM)
