boatman355
Feb 25, 2008, 10:58 AM
Post #5 of 5
(96 views)
Re: [mikemaiertv] SAMSUNG 42HD43A NO PIC OR SOUND??
hi again mike, and THANK YOU!! for all your help!! my tv is up and running thanks to your input!! i replaced the kit and it works now!! i do have a couple more quick question, though?? first how do i or where do i get a screen jig for this tv?? when i was trying to figure out all the problems before your help i screwed up the screen lines!! also is that causing my perfect focus not to work right?? when i push the perfect focus button all i get is CHECK FACTORY DATA !! so how do i do that ?? for now i have a pretty good pic but i am sure it can be better!! i have adjusted the focus manually and it is pretty good but i know i have something not right!! i am not sure where the lines should start in relationship to the little screen side markers on set!! the ones on the sides and top and bottom. i will tell anyone reading this that if mike canT help you , buy a new TV!! PLEASE RESPOND a.s.a.p. i have set in my heated garage and want to put it back in my livingroom where it belongs!! once again thank you for all your help and input!! m bammel
