Samsung - CRT or Convergence ICs???
tyerant
Mar 15, 2007, 12:31 PM
Post #1 of 5 (567 views)
Samsung - CRT or Convergence ICs??? Can't Post
Hi all,
I have been reading and reading but can't seem to confirm my suspicions...
My Samsung HCN473W went the other day. It looked like the GREEN was out of convergence. I did the perfect focus a few times but it only goes to 4% and stops. So, I did a manual convergence through the normal menu (Not the mute-1-8-3). After that, the green went all blurry ,way out of focus and flutters from time to time.
So, my question is...Is it just the green CRT gone or is it the convergence board?
I was told that the Green CRT is static and the convergence board would not fix the Green convergence/focus problem. .
Is this correct or should I buy the convergence board and see?
Thanks!
mikemaiertv
Mar 16, 2007, 8:12 PM
Post #2 of 5 (559 views)
Re: [tyerant] Samsung - CRT or Convergence ICs??? [In reply to] Can't Post
This problem is cover extensivly on this and many sites like it, use key words like CONVERGANCE or STK392-040 your set has a convergance problem, The number one cause of grief with projection tv owners, and your convegance Ic's the STK392-040's are shot
tyerant
Mar 16, 2007, 9:08 PM
Post #3 of 5 (556 views)
Re: [mikemaiertv] Samsung - CRT or Convergence ICs??? [In reply to] Can't Post
I did do an extensive search and came to the conclusion that I think it is the convergence board. However, in talking to the Techs at the place I got a quote from, I am told that my green CRT is bad as well. I find it hard to belive that these 2 issues could suddenly occur at the same time.
Plus I still see the green cross hairs, they are just blurry and flutter. The tech said that the green CRT is sationary and the convergece board will not fix the blurry green.
Will a convergence issue cause the green to go blurry and flutter?
Thanks!
(This post was edited by tyerant on Mar 17, 2007, 4:04 PM)
tyerant
Mar 17, 2007, 9:50 PM
Post #4 of 5 (545 views)
Well,
I took a gamble and picked up a brand new convergence board. Installed it and hit the "Perfect Focus" and.... No difference :-( It went to 4% and kicked out.
The Green is all fuzzy so I did the Mute-1-8-3. The green grid was messed up big time. I aligned everything as best I could, saved, and exited. It looked better than before but still bad. I thought one more "Perfect Focus" and it would be good... Nope... No Sensor Data. What is wrong???
I am down $200 Canadian and bumed out! PLEASE HELP
Attached is a pic of the green. It shows how fuzzy the green is. What is wrong?
Thanks
Attachments: Samsung.jpg (717 KB)
Mar 18, 2007, 7:00 AM
Post #5 of 5 (543 views)
this is a focus problem not convergence.have you adjusted the green focus control.probably the crt croaked as you were told
