Samsung HELP HELP HELP HELP HELP HELP
sigon
Nov 1, 2007, 1:07 PM
Post #1 of 6 (412 views)
Samsung HELP HELP HELP HELP HELP HELP Can't Post
Hi everyone, so I figured this is the place to come for help with my tv, here is my problem.
My tv is showing two pictures. Anyways here are the specifics of the TV and a few pictures to go with it. If anyone could Let me know how to repair this or direct me toward the part I need to repair the TV.
Samsung 1080i HDTV
Auto Perfect Focus
Model # HCN4226X
SVC Model - HCN4226YX/XAA (the y is either a y or x)
Serial# 3CEY700520P (y either y or x)
Type No. P55A CM42Y8
120V-60Hz 240 Watt
Chassie No. P55A
Nov 1, 2007, 1:52 PM
Post #2 of 6 (406 views)
Re: [sigon] Samsung HELP HELP HELP HELP HELP HELP [In reply to] Can't Post
you need to change the two big ic's in the 2nd last pic marked STK392-040 and check nearby low value resistors for open circuit and change them as well
sigon
Nov 1, 2007, 7:55 PM
Post #3 of 6 (397 views)
Re: [techchris] Samsung HELP HELP HELP HELP HELP HELP [In reply to] Can't Post
Ok now can you put it in terms that someone that has never fixed a tv can understand.
I get about changing the two STK's
But where would i get those? Can you point me in the right direction?
And what resistors are you talking about? And where can i get those as well?
Your help is greatly appreciated
Thanks
Juan Medina
Nov 2, 2007, 11:24 PM
Post #4 of 6 (343 views)
Is it two pictures or one? The pic you posted looks like the crt are not aligned. Kinda like when you set it up to see a 3d movie. You could try to use the settings to fix the problem. Visit this site for more info on rear projection tvs. www.buyyourtvhere.com
good luck
Nov 3, 2007, 1:19 PM
Post #5 of 6 (334 views)
you need to be good at soldering to change them. dont start the job if you are not confident about it.better to call in a local tech.the resistors are low value(less than 5 ohms) and should be right by or between the ic's.i dont have the schematic for this model so cant tell you the position numbers,sorry.order parts from manufacturer or local agent but dont buy cheapo Chinese equivalents as they will only last a couple of weeks and fail again.
mikemaiertv
Dec 6, 2007, 9:10 PM
Post #6 of 6 (327 views)
Lets just go at this simply, the second pix shows that at least the green fills the screen this tells us that both voltages are at the convergance board, Never attept to enter the service mode to fix a electrical failure as sugested above this will cause more problems than its worth, replacing just the Ic's is a good Idea but your knowlage of how to test resistor seems to come up a little short so the simplest way would be to replace the entire board on the upper left of pix 7, this has the STK392-040 on it. Also by replacing the entire board you do not run the risk of buying the cheepo Ic's to save some cash. And finaly this is a simple unplug and re-plug thing. Part number BP95-00142E about $75.00 at www.vancebaldwin.com
