Gus67
Jan 7, 2010, 3:24 AM
Post #3 of 5
(2123 views)
Re: [tomcarter1981] Samsung PCJ612R crt coolant change
Tom, I just changed the fluid in my phillips 55" with unbelievable results.It was not hard at all.If you read all the posts on fluid changing, your head will spin off your neck.I have a strong mechanical backround and I am also an Electronics tech. Supervisor (with NO TV BACKROUND). Hell,I did not even know projection tv's had cooling fluid until a month ago. There was little to no electronics involved in the task. If you have any mechanical knowlege you should be able to handle it.As far as adjusting the convergence.There is no way that you will not get around it. I was able to change the fluid without removing the CRT's.I took my time,read a lot of posts,and was sucessful.Dont let it scare you.It's not that hard. Read some more,think about if you are up to it.There is plenty of info on this site to get you through it.
